500 scrambler raw fuel
Old Dec 28, 2013 | 05:09 PM
Steven Bandemer's Avatar
Default 500 scrambler raw fuel
I just changed the cam shaft again - it ran awsome for about 2-4 mintues had a lot of trouble to restart. Now when i crank it, pure fuel is coming out the exhaust. Seems to be alot of fuel for a 4wheeler to idle -10 cranks get around a cup of fuel. Never touched the carb, and did run before this.
Timing has been checked and rechecked,Valve's have been set.
Idea's??
Old Dec 29, 2013 | 05:35 AM
Pure fuel coming out of the exhaust just means fuel isn't being ignited either from carb problems or mechanical problem. Compression,rings/piston,leaking valves,etc. Start at the easy part,the carb and eliminate it as a problem first. Plus this is a sensitive carb and float must be set right. Here's one similar to your BST40 carb on a KTM. Plus carb kits are available on Ebay. http://www.advrider.com/forums/showthread.php?t=347184
Old Dec 29, 2013 | 08:43 PM
Okay yeah had the fuel lines crossed.......Now it runs great starts right up idles - than dies...Fires right back up same thing, runs few 20 seconds dies again.... I ordered a carb kit off ebay but, what else could cause this runs fine wide open
Old Dec 29, 2013 | 08:49 PM
Worn needle and seat can cause too much fuel at idle along with the float level if not set correctly.Can take the fuel at higher rpms,but will usually stumble and die at an idle if this is the case. After you install the carb kit make sure you adjust the float level as pictured.
Old Dec 29, 2013 | 08:54 PM
Yeah i think its even leaking.......so i will try that for sure THANK YOU!
mitchxc700
Aug 19, 2015 02:41 AM
scram5050
Aug 19, 2015 02:19 AM
mitchxc700
Aug 10, 2015 09:26 PM
1000gade
Aug 9, 2015 03:34 PM
maxjung
Jul 13, 2015 05:11 PM
