Oil change suggestions
Old Jan 4, 2014 | 04:21 PM
F5guy's Avatar
Default Oil change suggestions
Certainly don't want to start a hassle here since I've seen my share over oil and tires on various forums. The question I have for anyone with experience is : any benefit to switching a 2000 xpedition to Ams oil at this stage. Original owner told me he's used the Polaris stuff since day 1. I use Ams exclusively in everything I own (except the wife's car). Thanks in advance.
Old Jan 5, 2014 | 08:42 AM
Al-53's Avatar
yes you will be fine switching over to amsoil....if you want you can try the Rotella T6 5-40 also..its a great oil for these machines....it had a good additive package..heavy duty..an its a full synthetic also....I use the Rotella and for rest of fluids i use the amsoil but I do use the Demand drive plus for the hubs...till I run out...
front diff I use Amsoil severe ger lube
transmision I use Amsoil chaincase oil....
anti freeze I use amsoil anti freeze
oil filter I use either Wix or Puralator Pure Onei
I also Add 2-3 oz of liqui moly anti friction to engine oil...for the winter cold starts
not a tick in the engine ..runs smooth....
Old Jan 6, 2014 | 09:29 AM
TLC's Avatar
TLC
It does not matter ,the main thing is both the OEM Polaris oil and Amsoil are full synthetic.
I use to go back and forth all the time when my dealer sold a oil change kit for only $25. He raised his prices so now I just use 0w-40 Amsoil and a aftermarket oil filter from walmart or Canadian tire.
Old Jan 6, 2014 | 08:25 PM
F5guy's Avatar
Ordered amsoil fluids and filters. Will tackle Bendix once it warms up a bit. Any other preventative measures or adjustments beyond greasing I should do to this new to me machine.
Old Jan 7, 2014 | 12:44 AM
You didn't say whether you have an Expedition 325 or 425. If it's the 425 hope you ordered 6 quarts of oil as it takes 5.5 quarts plus filter. A good service manual is worth the money.http://www.ebay.com/itm/Polaris-2001-Xpedition-325-425-Factory-Original-Service-Repair-Manual-/121219452941?pt=Motors_Manuals_Literature&hash=item1c393e100d&vxp=mtr
Old Jan 7, 2014 | 09:01 AM
F5guy's Avatar
It's a 425 Amsoil 4 stroke power sports oil comes in cases of12 so I'm covered. Going to dl the manual this afternoon. Thank you for all you help.
My list is
Fluids - oil, trans, diffs, coolant
Grease
Plugs
Install Fuel filter if there isn't one
Old Jan 7, 2014 | 10:33 AM
TLC's Avatar
TLC
You didn't say whether you have an Expedition 325 or 425. If it's the 425 hope you ordered 6 quarts of oil as it takes 5.5 quarts plus filter. A good service manual is worth the money.Polaris 2001 Xpedition 325 425 Factory Original Service Repair Manual | eBay
Really that much oil? I thought the 425 same motor as the 500 but for the bored and stroked.
Do they just have a much larger oil tank?
Old Jan 7, 2014 | 11:27 AM
No oil tank on the Expedition as all the oil is internal and has a internal 5 speed gear box and wet clutches similar to Honda and Yamaha. Surprised me when I did my first oil change on one as to how much oil it took.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Jan 7, 2014 | 12:25 PM
TLC's Avatar
TLC
Never seen a xpedition before. I did not know Polaris made a utility foot shift ATV.
Makes since , twice the oil because the oil has a second job.
Old Jan 7, 2014 | 12:41 PM
Yes,but most other machines take about 3 quarts on oil and filter changes for this size engine,not 5 1/2. Even my old Honda 750 holds only 3.1 quarts including the oil cooler. When I drained my first Expedition I thought it was gas contaminated because of the amount in the pan.That's when I pulled the manual and saw the 5.5 quarts listed and it took that amount to refill it.I think Polaris may have been a little scared about the internals and over compensated with this engine
cornermike
Aug 10, 2016 06:47 AM
toonces
Oct 19, 2015 02:21 AM
toonces
Aug 6, 2015 10:46 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
