2005 Polaris won't start
Old Jan 6, 2014 | 04:47 PM
Flyin421honda's Avatar
Default 2005 Polaris won't start
I have a 2005 Polaris 400 and when I turn the key it just clicks one Time I have no power to my starter and battery is new reads 11 volts and other funny thing when I try to jump the solenoid nothing happens I can touch my neg and positive cables that go to the starter and no spark is my solenoid bad??? I can hook cables to my battery and get spark when I touch neg to positive plz help
Old Jan 7, 2014 | 12:30 AM
Don't touch neg to pos cables. Can cause more damage. If the battery is good as you say,jump the solenoid posts with a screw driver.Plus you can try 12 volts directly to the starter.If the starter still doesn't work,might be time to get a new one. Not that it should have anything to do with the starter itself,but the ecm module can do some strange things even if it was replaced during the recall. Huge ATV Recall by Polaris - Sportsman and Scrambler
Old Jan 8, 2014 | 11:36 AM
I've tried jumping the posts and nothing no spark or anything
Old Jan 9, 2014 | 01:58 PM
Then you can double check the wire from the solenoid to the starter plus you can just hook 12 volts to the starter itself. Tap the starter body and see if it tries to turn over. If it's a bad starter you can get them pretty cheap here.DB Electrical - Polaris
hoopduerr
Jun 10, 2015 03:00 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
1000gade
May 27, 2015 12:37 PM
May 27, 2015 11:15 AM
