500 sportsman H.O. gas problem.
Old Jan 15, 2014 | 07:59 PM
MUD HOLE KILLA's Avatar
Default 500 sportsman H.O. gas problem.
my sportsman is leaking gas into the air breather box when the four wheeler while it isnt running? ik i can just shut off the gas after im done riding it, but the gas leakage is getting aggervating. if i leave it on for more than 2 our the gas willl be up to almost the air filter. someone please shed some light on this issue for me.
Old Jan 16, 2014 | 08:16 AM
TLC's Avatar
TLC
Usually leaking gas is just a carp float adjustment #37 or the needle assembly needs cleaned or changed #36.
Even if the carb leaks I though the over flow tube just goes to the ground not the air box on all carbs.
Old Jan 16, 2014 | 09:57 AM
Worn/sticking needle and seat as mentioned,but don't overlook any contamination of gas in the oil tank that could possibly thin the oil down and cause engine damage. If gas is getting into the air box,it's probably getting into the oil also.
Old Jan 16, 2014 | 09:59 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check your oil for the smell of gas. if there's gas In the oil then change it as mentioned. clean the carb when you have it apart as well.
Old Jan 16, 2014 | 03:55 PM
if i do find gas in the oil, how do i fix this problem? dose the carb just need to be cleaned or do i just need to get a new carb all together?
Old Jan 16, 2014 | 04:18 PM
If really contaminated you can smell the gas on the dip stick. If in doubt 2 quarts of oil and a filter is cheap insurance. Carb kit should solve your problem. http://www.ebay.com/itm/Polaris-Sportsman-500-2003-2004-2005-Carb-Carburetor-Kit-/400627265557?pt=Motors_ATV_Parts_Accessories&hash=item5d473ef015&vxp=mtr Plus make sure the float is set correctly after you install the kit.
Attached Thumbnails 500 sportsman H.O. gas problem.-2471649347_b2a1a773d6.jpg
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
400H0
10
Aug 20, 2015 07:34 PM
AlotL1keVegas
Aug 18, 2015 09:38 PM
ltrmc02
Jul 22, 2015 04:50 AM
