2000 SP 500 pulling hard right, then left
Old Jan 17, 2014 | 05:14 PM
Siskiyou's Avatar
Default 2000 SP 500 pulling hard right, then left
I was out yesterday running in 4 wheel and noticed at one point it was pulling hard to the right. I stopped for a minute and took off again and it went away. Then a few minutes later it was pulling hard to the left and then went away in less than a minute. It never did it again in an hours run. I was only going maybe 1-2 mph at the time. Any idea what the heck that was?
Old Jan 17, 2014 | 05:49 PM
jgar's Avatar
I have the same quad and have had the same issue. What I have noticed with my machine is it starts when I back up in awd. If I back up any distance I take it out of awd and have no problems with pulling.
Thought it might be a issue with the front end. This fall I rebuilt the front end. Replaced the front diff, strut bearings, wheel bearings, armature plates among many other parts. Everything was torqued to spec and I used the real demand drive fluid. Still had the same issue, occasionally.
When my 500 starts pulling it feels like 1 of the front tires is engaged and the other is not. Even tho the rear tires are not breaking free.
Old Jan 17, 2014 | 06:14 PM
Siskiyou's Avatar
Well... it's nice to know I'm not alone. Out of curiosity, do you have 4 wheel in reverse? I don't. This is my first quad and I'm in for a learning experience I can see.
PS. You're right. It WAS just after I had backed up, now that I think about it. I was just a bit concerned that it might want to do that when I was at a higher speed. That wouldn't turn out very well.
Old Jan 17, 2014 | 06:15 PM
When awd fluid is cold at first start in the morning I've had a bunch do this. Some would unlock after a short while,some I'd have to stop, back up then go forward to unlock em. Seems like it happened a lot more in winter than summer.I think the armature plate is dragging/sticking on the sleeve letting the hillard ramp up in the hub. Just a nuisance with the hub system.Once the oil moves around and warms up the system works well.
Old Jan 17, 2014 | 06:21 PM
Siskiyou's Avatar
Good to know. It was in the mid 20's when I went for a ride. I'll just stay away from sharp cliffs till it warms a up a bit. Scared the crap out of me the first time. I was only 2 feet to the edge and pulled that way. Almost had to clean my britches.
Thanks you guys!!
Old Jan 17, 2014 | 06:44 PM
jgar's Avatar
On the left side of the handlebars under the start button is a yellow button, reverse override. As long as you have the yellow button depressed you will have awd in reverse.
Old Jan 17, 2014 | 06:54 PM
Siskiyou's Avatar
Well that's nice to know. No manual came with this thing and I haven't found one in the short time I've had it. It is on my minnie bucket list though.
Thanks jgar.
Old Jan 17, 2014 | 07:11 PM
jgar's Avatar
No prob.
I got mine about 8 months ago. Its the first 4x4 I have owned. Spent the last 20+ yrs on sportys. When I first got the popo couldnt even figure out that you push the start button up to start it.
rcappie4
Jul 10, 2015 04:54 PM
coolguy420
Jul 10, 2015 01:17 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Mikea1978
Jul 4, 2015 12:37 PM
