Upper Radiator hose '02 Sportsman 700
Old Jan 20, 2014 | 08:00 AM
SnowDrift's Avatar
Default Upper Radiator hose '02 Sportsman 700
I notice where the vertical frame support has cut into my hose. There is actually a "guard" over the hose to delay the inevitable. Is this really a $50-60 hose?
5413762 appears to be the P/N I need. I noticed it yesterday when I went to take it out for a ride, but thinking it was just a 1" OD hose, I was thinking of just buying a section of heater hose if we didn't already have some sitting around in a roll. After looking it up, it looks like there is some sort of special end on it, though. Does this sound right? I've not looked too close at the engine side of the hose.
Old Jan 20, 2014 | 08:10 AM
It's flared to help slip over the fitting,but you can try a straight piece of water heater hose and see if it works or do as some people have done. Just cut the bad part of the hose out and use a piece of brass/galvanized tubing and clamps to join the pieces back together.Item #19. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Jan 20, 2014 | 09:10 AM
SnowDrift's Avatar
much better idea! thanks, OPT. I figure I'll try to put a loom on the edge of that steel vertical piece, but I like the idea of a metal connector, so that it's not rubber on metal again.
Thanks, again!
Old Jan 24, 2014 | 10:45 AM
SnowDrift's Avatar
I picked up a 3/4" copper coupler for this splice piece. Everything else I saw seemed like it was going to narrow down the cross section too much to make me comfortable. I heated the hose with a hair dryer and pushed the coupler inside. It's pretty tight, to say the least, but I won't restrict the flow. I'll clamp each side, obviously.
Does this sound about right?
Old Jan 24, 2014 | 11:10 AM
Sounds good. I've had several customers do this because of hoses rubbing against the vertical frame piece. Flow isn't restricted.Just zip tie some loom against the vertical piece plus loom on the spliced in piece should solve any future problems. Don't forget to leave the radiator cap open to bleed any trapped air in the system.
Old Jan 25, 2014 | 07:42 PM
SnowDrift's Avatar
What I ended up doing was putting some door edge molding on the edge of that vertical piece. Then I zip tied a hose to it (hose cut lengthwise). The way I see it is if the hose ever vibrates out of position or gets torn off, somehow, the sharp edge is not present anymore with the edge molding there.
SDR-II
Sep 29, 2015 01:06 AM
Big bousse
Sep 26, 2015 10:42 AM
ltrmc02
Jul 22, 2015 04:50 AM
ghost civic
Jul 20, 2015 12:36 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
