2000 500 Scrambler
Old Jan 23, 2014 | 07:49 AM
cwilson1972's Avatar
Default 2000 500 Scrambler
I got the fuel bugs and many others worked out, ran great, however my carelessness again left me with a non running machine. I had disconnect my winch while working on some things under the hood covering, the wire for the winch switch hit the blue/white wire tab on the coil, shorted out, stopped running. I took this from another thread:
OPT:
Good video,but he doesn't give the resistance specs on the stator or coil even though he's got the manual in front of him! The stator pulse coil wires leading to the cdi (white to white/red) should be 97 ohms + or- 20%. The stator exciter wires leading to the cdi(Blk/Red to Green) should be around 446 ohms resistance + or - 20%. The coil primary(coil tab to ground) .3 ohms. Coil secondary (coil tab to plug wire,cap removed) 6.3k ohms. If you still don't have spark after cleaning the pulse coil use a meter to check these resistance values on your 97 model. Hope cleaning the stator and pulse coil solves the
The stator pulse coil wires leading to the cdi (white to white/red) should be 97 ohms: Pass
The stator exciter wires leading to the cdi(Blk/Red to Green) should be around 446 ohms resistance: Fail
The coil primary(coil tab to ground) .3 ohms: Pass
Coil secondary (coil tab to plug wire,cap removed) 6.3k ohms: Fail
Now I did buy a new cdi unit, a Ricks... My wiring for the on my machine for the stator exciter red/red blk. On that connector on the cdi unit it has 3 prongs, 2 male 1 female. It has red/blk and red like my bike, the third is green. The Green/red combo is the only way the cdi will connect to the harness plug. Is this ok? (I got the Rick's CDI because I got a good deal. Any help would be appreciated, I know it is a long post. I think it needs a coil, however, the stator exciter to the cdi has me unsure.
Old Jan 23, 2014 | 10:12 AM
Exciter wiring colors changed over the years. Whether yours is a red/black or whatever and the resistance is bad the stator needs to be replaced. Ricks and Ricky stator both have been known to swap wiring around,but try it as you mentioned and see if you have spark.
Old Jan 23, 2014 | 10:35 AM
so it is possible to fry the stator by the coil being grounded out? Do you think the coil is bad as well? I got no resistance from the plug wire to the coil. Thanks for the help
Old Jan 23, 2014 | 10:41 AM
Anythings possible when it comes to stators. Check the coil wire for any breaks. Some models you can pull out the wire from the coil and replace it with 7mm plug wiring from a local auto store. If this one is sealed and you get no resistance reading from the wire back to the coil tab,then yes it needs replacing.
exmotocrosser
Sep 13, 2019 06:12 AM
Gwolf228
Feb 18, 2017 01:36 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
