Confused!! HELP!?
Old Jan 23, 2014 | 03:07 PM
jhansen101's Avatar
Default Confused!! HELP!?
So I have a 110cc Chinese ATV and when I try to start it, it cranks fine but there's no pop like it wants to run. There is good spark and compression. Any ideas what could be wrong?
Old Jan 24, 2014 | 09:46 AM
Zrock's Avatar
Super Quad Patrol
new or used? Did you check for a few on/off valve? Do you have a drain on the bottom of the carb? Crack it open and see if you have a good flow of fuel. let it flow for a few seconds to try and help get all the air out of the bowl. I have had issues before trying to get them to start due to a air lock in the carb or fuel line. If none of these work take a old squirt bottle fill with fuel hold the throttle wide open and give a few squirts and let go of throttle and try to start. Might take a few tries and you may have to keep giving it a squirt to keep it running once you get it started to get things flowing. Or if you want you can use quick start but use it wisely
Old Jan 24, 2014 | 02:24 PM
Ace1996's Avatar
Fuel problem. Probably needs a carb clean.
Old Jan 24, 2014 | 05:00 PM
jhansen101's Avatar
I've cleaned the carb and had problems with the needle but got that fixed. There is good flow. When I open up the drain screw gas comes.out of.the overflow instead of where the drain screw is at. Could that be a problem?
Old Jan 24, 2014 | 07:16 PM
jhansen101's Avatar
akguy31
Aug 31, 2019 04:34 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Pissed off
Sep 21, 2015 02:33 PM
Halffast17
Sep 11, 2015 02:30 PM
Jason Campbell
Sep 7, 2015 02:25 PM
