Confused!! HELP!?
Old 01-23-2014, 03:07 PM
jhansen101's Avatar
Default Confused!! HELP!?
So I have a 110cc Chinese ATV and when I try to start it, it cranks fine but there's no pop like it wants to run. There is good spark and compression. Any ideas what could be wrong?
Old 01-24-2014, 09:46 AM
Zrock's Avatar
Super Quad Patrol
new or used? Did you check for a few on/off valve? Do you have a drain on the bottom of the carb? Crack it open and see if you have a good flow of fuel. let it flow for a few seconds to try and help get all the air out of the bowl. I have had issues before trying to get them to start due to a air lock in the carb or fuel line. If none of these work take a old squirt bottle fill with fuel hold the throttle wide open and give a few squirts and let go of throttle and try to start. Might take a few tries and you may have to keep giving it a squirt to keep it running once you get it started to get things flowing. Or if you want you can use quick start but use it wisely
Old 01-24-2014, 02:24 PM
Ace1996's Avatar
Fuel problem. Probably needs a carb clean.
Old 01-24-2014, 05:00 PM
jhansen101's Avatar
I've cleaned the carb and had problems with the needle but got that fixed. There is good flow. When I open up the drain screw gas comes.out of.the overflow instead of where the drain screw is at. Could that be a problem?
Old 01-24-2014, 07:16 PM
jhansen101's Avatar
akguy31
08-31-2019 04:34 AM
Roro
Ask the Editor
09-30-2015 10:58 AM
Pissed off
09-21-2015 02:33 PM
Halffast17
09-11-2015 02:30 PM
Jason Campbell
09-07-2015 02:25 PM
Quick Reply: Confused!! HELP!?
