2000 500 magnum oil pressure
Old Jan 25, 2014 | 09:44 PM
spits's Avatar
Default 2000 500 magnum oil pressure
I got the 500 back together finally and did as the manual says to get oil pressure before I fire it. I cannot seem to get any oil pressure evan to the filter. It had pressure before I started this project and didn't touch anything related to the oil or coolant pump. How long should it take to get pressure? this is the first engine I've worked on with a dry sump. Thanks in advance.
Old Jan 26, 2014 | 08:04 AM
Shouldn't take over a minute or so for the oil pump to prime up when you clamp off the vent hose on the oil tank.
Old Jan 26, 2014 | 08:24 AM
spits's Avatar
thanks. I'll give it a try.
Old Jan 26, 2014 | 12:43 PM
spits's Avatar
Will I see oil on the rockers or going to the tank on the return when it is primed or does the engine have to be running to get that pressure.
Old Jan 26, 2014 | 01:15 PM
All that blocking off the oil tank vent does is to allow more oil,less air for the pump to prime up quicker ,fill the oil filter,lubricate the top end and return to the tank quicker. Yes the engine has to be running for minute or so for this to happen.When you release the vice grips from the tank vent line you normally hear an air hiss from pressure build up in the tank.The pump is primed.
Alex G.
Sep 11, 2017 11:38 PM
Gwolf228
Feb 18, 2017 01:36 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
2many2ride
Sep 27, 2015 04:35 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
