2002 Polaris Sportsman 700 small oil drip
Old Feb 1, 2014 | 08:02 PM
dsiggi's Avatar
Default 2002 Polaris Sportsman 700 small oil drip
hey guys, so I was looking at the bottom of the bike the other day as its been getting run pretty hard with this winter with all the snow we have been getting and i noticed a tad bit of oil on the lowest part of the gasket (i think #10) on the crankcase on the right side of the atv.....
thoughts? I've been watching it oil is still at same level after many hours of running and all i have to wipe is a drip or 2 on it, most of the time it doesn't even accumulate enough to drip on the frame below it....
Thoughts? i assume the gasket is just a little leaky?
2002 Polaris SPORTSMAN 700 (A02CH68AA/AB/AC/CA/CB) Crankcase | Cheap Cycle Parts
Old Feb 2, 2014 | 05:49 AM
I'd just keep a check on it and replace the case gasket only if it gets worse on the leaking. Couple drops of oil isn't worth having to pull the flywheel and stator,pull the cover,install a new water pump seal and oil seal and case gasket. Especially if the oil level stays up. You might try to snug up the cover bolts and see if it helps.
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
coldnorthpol
Jul 14, 2015 11:22 PM
coolguy420
Jul 10, 2015 01:17 AM
Shifts
Jul 3, 2015 07:59 AM
