Tire Repair
Old Feb 12, 2014 | 10:56 AM
Siskiyou's Avatar
Default Tire Repair
I was curious what you guys are using to fix a flat tire out in the field. And once it's fixed, is there a co2 type setup to air it up once the tire is patched?
Old Feb 12, 2014 | 11:09 AM
scootergptx's Avatar
Supersock
Hired Gun!
Fix a flat is a very messy thing to use. Tire slime, a patch kit and a co2 filler will work much better.
Something like this. There are other brands and styles too. Just an example of what's out there that is much better than fix a flat.
Old Feb 12, 2014 | 11:11 AM
TLC's Avatar
TLC
Many different methods. There is Fix a flat in a can that blows the tire up and plugs hole.
There is pre loaded "slime" which automatically stops a leak as it happens. Run over a nail and you would not even know it until you get home..
My favorite is tire plugs and we carry a small DC air pump.
with
Old Feb 12, 2014 | 11:24 AM
Supersock
Hired Gun!
I should say that tire slime is messy too. But I've used fix a flat and it was a total pain to try and clean off the rim and tire.
Old Feb 12, 2014 | 11:30 AM
TLC's Avatar
TLC
I had a tire shops place get angry with me when I used slime. LOL They charged my extra for that mess.
The plugs can do bigger holes, just keep adding strips until it holds air.
Slime and Fix a Flat only fix so big of a hole.
Old Feb 12, 2014 | 11:31 AM
In the groups I've ridden with we've fixed over a dozen tires in the woods. One of mine was a nasty side gash that took 3 plugs. We aired it up with a small Slime compressor. Held air, not only for the rest of the ride, but until I got new tires, about 1,000 hard miles later. Where quad tires are very low pressure I'm not too worried about side wall repairs.
Old Feb 12, 2014 | 11:37 AM
Supersock
Hired Gun!
The first ride I took on my quad, I got a slice in the tire. Had some fix a flat and it slowed the leak down. Slime slowed it down a little better. Plugging it worked for about 2 years. Man that was a mess inside the tire.
After that I just used plugs.
You could use a hand pump too. But it's not the pressure that will keep you pumping till you get tired. It's the volume you're trying to fill.
Old Feb 12, 2014 | 11:46 AM
TLC's Avatar
TLC
Flats be gone.
Old Feb 12, 2014 | 12:01 PM
Siskiyou's Avatar
I've been looking at dc pumps and find that several buyers have a less than favorable opinion of the one they purchased. Which one are you happy with?
Is it made here in the states?
Old Feb 12, 2014 | 12:20 PM
TLC's Avatar
TLC
The one I use is just a cheap $5.99 one from Canadian Tire. I just rap it in a small towel and stick in under the seat so it does not get banged up.
On our big fishing trips we carry more then one in our group, so one has to work. A hand or foot pump will work as well. Your only asking for 5psi.
Found out my 350 does not even have a DC plug in which sucks.
