brown wire on voltage regulator
Old Feb 14, 2014 | 05:40 PM
capt bart's Avatar
Default brown wire on voltage regulator
i recently became the new owner of a 2000 polaris magnum 500 . the old flywheel decided to give up one of its magnets and subsequently trashed the stator . i have replaced all of this mess with the updated flywheel , stator and cdi . before i took the old junk out i noticed that the brown wire on the voltage regulator was not connected to anything . i figured i would find out where it is supposed to go when i got in there and had a closer look . no such luck . after looking over the wiring diagram the most logical place looks to be on the ground side of the coil with the other brown wires . i figured it was better to ask someone who knows for sure instead of learning the hard way . thanks , your help is greatly appreciated . capt bart
Old Feb 14, 2014 | 06:40 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Can't say without seeing it, but brown is ground on a Polaris. That much is for sure.
Old Feb 14, 2014 | 06:52 PM
Like readymixer169 said brown is ground on Polaris. Tried taking a pic from a 2000 Spts 500 manual. Don't know how good it looks,but see where the brown goes. You can tie it anywhere and coil mount is as good as any.
Old Feb 14, 2014 | 09:06 PM
capt bart's Avatar
thanks gentlemen - thats what i thought but i wanted to double check because they don't give these polaris parts away for box tops . capt bart
Bulgin88
Aug 1, 2015 06:39 PM
ScopeZ_
Jul 28, 2015 01:44 AM
DeFox500
Jul 26, 2015 06:32 PM
Schneider
Jul 24, 2015 05:05 PM
200es
Jul 19, 2015 04:50 PM
