02 400ex popping and backfiring
Old Feb 16, 2014 | 05:50 PM
CentraliaTom's Avatar
Default 02 400ex popping and backfiring
Ill try to make a long story short. Quad has sat for extended periods of time. Last time it sat we took it in and had the valves adjusted tune up etc. Not long after that it sat again for a while, like maybe for 1 year. Now when i can get it to start it pops and sputters. I replaced the plug and added fresh gas to the tank (It was almost empty) Still does it.
Does this sound more like a bad valve adjustment or am i need of a carb rebuild/cleaning?
If it is a carb issue is there any good write ups on how to rebuild a 400ex carb?
Old Feb 16, 2014 | 06:15 PM
Scooter86's Avatar
Knows Old ATV Questions!
The most likely culprit is a gummed up carb/jets from sitting with gas in the float. I am sure you could do a youtube search and find a decent tutorial. If it doesn't have many hours since the last valve adjustment I doubt it would be the issue. BTW, adjusting the valves on that should be pretty easy as well, just need a feeler gauge and a little patience/common sense.
Old Feb 16, 2014 | 06:51 PM
quadsr4me's Avatar
Air filter clean?
Old Feb 22, 2014 | 07:26 PM
MarioWeldingInc's Avatar
sounds like you are running a little lean. Might be a fuel or carb issue
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Alex G.
Sep 11, 2017 11:38 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
r1pilot83
Sep 27, 2015 07:38 PM
