Knock/Hick-up at idle
Old Mar 2, 2014 | 08:42 PM
doggster's Avatar
Default Knock/Hick-up at idle
I just picked up an '00 Xpedition 425. Changed the oil, plug, and cleaned the fuel system. Now that it is running and driving everything seems to work well except at idle when it is cold. Seems to have an occasional knock or hick-up coming from the left side of the crank case from time to time. This does not have while the RPM's are up. Any ideas?
Old Mar 2, 2014 | 10:21 PM
quadsr4me's Avatar
Seems pretty typical for carbs in cold temps. Just turn out your fuel screw a tad.
Old Mar 3, 2014 | 12:58 PM
Just noise from the two clutches while it's still cold. Occasionally you need to pull the blind plug,loosen the lock washer and adjust the clutch pressure screw. #28,#29,#33. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Can't find a free 2000 manual,but here's a 2002 for 5 bucks that can help on service.Not too much changed during it's production run from 2000 to 2002.2002 Polaris Xpedition 425 Service Manual PDF Download
wrencher82
Sep 30, 2015 04:27 AM
IMLN
Sep 28, 2015 03:32 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
