Wheel spacers to stop tire rub?
Old Mar 30, 2001 | 12:35 AM
WEETOOTS's Avatar
Who sells wheel spacers, so I can eliminate the tie rod to wheel rub. I don't need one to thick.
Thanks
weetoots
Old Mar 30, 2001 | 01:30 AM
Xplor's Avatar
To avoid the tie-rod end on the right side from rubbing, just add a couple washers the the wheel studs.
Old Mar 30, 2001 | 02:31 AM
Dazed's Avatar
They changed the front hubstut casting now you need to add washers to both sides. Also do your self a favour, pull off the rubber tie rod boots and save them, If you rip one it will just collect dirt and wear out your tierod end.Found out the hard way on that one.
Old Mar 30, 2001 | 11:29 AM
rangerchet's Avatar
To answer your question. highlifter sells spacers
and I saw on there web site a few days ago, they are coming out with something new. looks like a 1 inch and also a 1 and 1/2 inch aluminum plate to space out the wheels for the purpose of making your atv less tippie and so your not riding in the
same tracks as the guy in front of you. I have 2 washers on both sides of my front tires now.
rangerchet
Old Mar 30, 2001 | 02:59 PM
WEETOOTS's Avatar
Thanks Guys. The washers work great. Plus they aren't expensive. I will checkout "Highlifter" site.
weetoots
Old Mar 30, 2001 | 03:43 PM
ledebuhr1's Avatar
rangerchet,
did your tires still rub after u put on the ITP magnums?? dou know how much wider the magnums maker your quad??
and how did u find room to putthe washers and the lug nuts on with aftermarket rims??
thanks
later
jon
greg74
Sep 10, 2019 03:03 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
Jul 21, 2015 03:03 PM
rcappie4
Jul 18, 2015 07:51 AM
