416 smoking, pinpointed the problem, plz help
Old Mar 30, 2001 | 11:12 AM
KrazyNeighbor's Avatar
I have been mobil 1 for awhile now, and my quad has been smoking ever since. But not immediatly after i change the oil. I had my head reseated, and valve seals replaced. The rings are staggered correctly, and are in perfect position, with a proper break in.
The problem is i am buring oil. And i figured out that the mobil is breaking down too fast. Will a synthetic blend cause this? should i go back to honda non synthetic? if not what other sythetic/non synthetic oils could i try that WILL NOT HARM THE CLUTCH. last think i want to do is have to replace a slipping clutch. I am inexperienced in oils and their capabilities. Can someone plz inform me on some oils that i could use.
Old Mar 30, 2001 | 11:29 AM
Zorro's Avatar
Looks like your oil is too liquid (get a higher viscosity grade)...or you're putting too much of it...or your piston is almost dead...or...It never happened to me, so I can't really be ure of any..but these things up here should give you a direction.
Old Mar 30, 2001 | 12:16 PM
redrocker's Avatar
Try using castrol gtx 10-40 works great
never had a problem with it or in any
of the number of bikes I've had
Old Mar 30, 2001 | 01:18 PM
ridzhard's Avatar
Your best bet is to get the recommendation right from your engine builder or parts supplier. Other than that, I would recommend one of the four stroke engine oils made specifically for motorcycle engines with a wet clutch. A good parts counterperson can make a recommendation to you. Good luck.
Old Mar 31, 2001 | 10:00 AM
ok i found out a few things.
Fact - Mobil one tri-synthetic 15W 50 will not harm the clutch/ whatever, and works extremely well lubricating the engine parts. it also lats alot longer than regular non-synthetic oils.
Opinion of most users, and more - Mobi 1 15 50, tri - synthetic is the best oil you can put in your quad for 4 bucks a quart. there are a few more , 8 bucks a quart, i forget the names but they cannot be found in a convient location. (wal-mart, advance auto) they must be ordered.
the reason i was buring oil was because i was running very rich, causing the oil coating ont he cylinderwall to be burned, since i have rejetted it hasn't been smoking.
This also seems logical due to it only smoked at high rpm's.
thanks for the help
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
dirt ryder
Sep 27, 2015 09:22 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
