Kazuma utility need help bad
Old Apr 4, 2014 | 08:13 PM
Markus1005's Avatar
Default Kazuma utility need help bad
Ok got it for free the horn works the lights work I go to start it and no clicking of the silonoid or anything go to short it and the lights go off and everything it won't turn over and I'm out of ideas need help bad
Old Apr 4, 2014 | 09:00 PM
brumbear's Avatar
you blew the fuse replace it turn the key on kill switch on depress brake try to start that is if there's 12+ volts in the battery
Old Apr 4, 2014 | 09:13 PM
Markus1005's Avatar
The fuse doesn't look blown though
Markus1005's Avatar
If the fuse was blown the lights or horn wouldn't work correct ?
Old Apr 5, 2014 | 05:12 AM
Markus1005's Avatar
Ig I need to be more specific.. I got the quad for free it had no battery in it and hadn't been turned over in months. I take a battery out of my other quad and put it in the kazuma. I turn the key on the headlights work and the brake lights come on and the horn beeps. But when I go to push the start button it doesn't do anything. The silonoid don't click or anything. So next I proceed to short the silonoid just to see if it turns over. When I do that the lights go out and everything I check the fuse it is fine. So I unhook the wires from the battery and reconnect them and the lights come back on I've Tryed pressin on the brakes and everything hope this is clearer
Old Apr 5, 2014 | 07:53 AM
brumbear's Avatar
OK I assume you have 12+V in your other battery, turn key on kill switch on depress brake switch push start. If then nothing happens get yourself a test light and see where your problem lies BTW how are you shorting your soleniod ?
Old Apr 5, 2014 | 08:32 AM
Markus1005's Avatar
Using a screw driver to connect the 2 big wires together I'm gonna start back on it around noon I'll let you know how it goes thanks for your help
Old Apr 5, 2014 | 09:19 AM
brumbear's Avatar
OK
If you do what I posted and nothing happens here is what I would do
1 check the teather plug (usually under seat on frame left hand side) if its OK
2 get a test light hook it to ground put probe on small solenoid wire push button A-( light), bad solenoid or starter B-(no light) go to brake switch repeat all the way back to the start button I am pretty sure you will find your problem. BTW pull the spark plug it will turn over easier for testing purposes.
Johnny Mac
60
Dec 14, 2019 06:13 PM
Mar 22, 2016 09:55 AM
shimanok2
Jan 29, 2016 07:37 PM
cboler9
Sep 24, 2015 08:35 PM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
