Bogging issue
Old May 5, 2014 | 08:56 PM
Atlas91's Avatar
Default Bogging issue
Every time I go through a deep hole my atv Boggs out and stalls.i winch out and it runs fine after I'm clear.any idea as to what is causing this
Old May 5, 2014 | 08:58 PM
Atlas91's Avatar
It stalls around the seat level.no water in the air box.
Old May 6, 2014 | 01:11 AM
Could be water grounding out the plug.Use electrical grease around the plug boot and on all connections to help keep water from causing electrical shorts.Silicone the recoil handle(if you have one) to keep water out of the stator area(you don't say what model you have?) Plus if you run in water up to your seat expect problems. It's not a submarine even if you snorkel one..
Old May 6, 2014 | 07:10 AM
Atlas91's Avatar
What about cracks in the carb boots?
Old May 6, 2014 | 08:23 AM
Atlas91's Avatar
It's a 2004.5 polaris 600
Old May 6, 2014 | 06:06 PM
No need to post twice in the regular threads and expert section..http://forums.atvconnection.com/pola...cate-post.html
Old May 6, 2014 | 06:49 PM
Atlas91's Avatar
Which vents could cause this problem and if so how many vents are there on my atv
Old May 6, 2014 | 07:03 PM
Look at your other post in the expert section! I addressed some of what you're asking on the carb boots,plus with water up that high it can get into the clutches through the air exhaust and air intake in the clutch cover,the cover gasket itself,but usually if it does it would slip even if it cranked right back up when you're pulled out. The carb has vent line also that can suck water. PLUS you've never said what machine you have..
scram5050
Aug 30, 2024 01:39 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
cody500ho
14
Aug 14, 2015 05:03 PM
ghost civic
Jul 27, 2015 03:15 AM
