500 scrambler 4X4 clunk in reverse
Old May 6, 2014 | 07:26 PM
clok1966's Avatar
Default 500 scrambler 4X4 clunk in reverse
no noise in forward, but when shifted into reverse there is clunking, alot like a bad sprocket and chain. its possible the front sproket is bad, but I think its the tranny. any suggestion?
Old May 6, 2014 | 07:33 PM
Might help on knowing the year model as there were changes.
Old May 6, 2014 | 08:48 PM
clok1966's Avatar
sorry its a 2000. Strange thing is i bought it late winter and it was cold out.. no noise at all in my testing it, but i only drove it maybe 50 feet in reverse. its been sitting since. Have the problem with the one hub (front) not engaging but I think i got that covered from the threads here. Ordered some parts and was going to tear into front hubs.. but when i moved it this clunk appeared, right away, at first i assumed bad sprocket, but unless its the front one, i think its the tranny .. maybe the chain in their? but im surprised there is no sound in forward if the chain is that lose? or does it only work in reverse (chain in tranny not drive to rear axle one).. as I say, only in reverse.. works great in forward.
Old May 6, 2014 | 09:02 PM
Problem is there are TWO chains in this model tranny and could possibly be the problem. IF you tear into a tranny always replace both chains. Another thing is don't over look the prop shaft u-joints going from the tranny to the front diff.Could be as simple as worn joints causing the noise if you eliminate the external chain or sprocket.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
r1pilot83
Sep 27, 2015 07:38 PM
exmotocrosser
Sep 26, 2015 08:18 AM
