2008 hi-bird 250 wont crank over inless jump solenoid
Old May 16, 2014 | 08:41 PM
bcl319's Avatar
Question 2008 hi-bird 250 wont crank over inless jump solenoid
I have replaced the coil and whole starter kill switch assembly started fine up in till that point put old one back on it still wont crank over so put new one back on so I jumped the solenoid it cranks over just fine and starts any help will be a plus thanks
Old May 17, 2014 | 09:30 AM
Zrock's Avatar
Super Quad Patrol
check for a pin that may have pushed out of one of the connections
Old May 17, 2014 | 12:04 PM
bcl319's Avatar
checked them out everything is fine all did was remove the plastic and now it will not crank with the new or old starter button but will start up when jumping solenoid
Old May 22, 2014 | 03:15 PM
bcl319's Avatar
replaced the starter solenoid only will start when u jump it any help
Old Jun 10, 2014 | 08:44 AM
Jaster94's Avatar
i know you said "the switch is new" but you could have a blade that backed out not making contact or a wire pulled loose from the switch or a broken wire inside the jacket. use your ohm meter/multimeter and ohm the wiring out and you'll find it. if you can jump and solenoid and she starts, then your problem is up at the key or pushbutton start switch that Zrock is talking about.
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Atvnewb88
Aug 13, 2015 06:48 AM
Hatrackr
Aug 11, 2015 09:03 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
