02 blaster, good comp, good spark
Old Jun 25, 2014 | 02:40 PM
zrx11hooligan's Avatar
Default 02 blaster, good comp, good spark
Have a 02 blaster comp is round 145, has good blue spark, but wont start. To eliminate a fuel issue ive tried putting fuel directly into the cylinder occasionally sounds like it wants to start but wont. My leak down tester needs new regulator so unable to perform that test. Any ideas welcome.
Old Jun 25, 2014 | 03:03 PM
Just my two cents,I'd get the leak down tester repaired or start replacing crank seals,head and base gasket,plus you can't over look the engine case itself for leaks in the crank shaft area of the case. It has to have good top end compression, a good bottom end seal to compress the air/fuel mixture and shoot it up the transfer ports for ignition.
jace
Sep 10, 2020 08:30 PM
Bigredjeep
Apr 10, 2020 02:55 AM
tmoose
Jun 30, 2015 08:28 AM
Joe04785
Jun 15, 2015 03:12 AM
hoopduerr
Jun 2, 2015 09:01 AM
