bogging problem
Old Sep 4, 2014 | 09:17 PM
breonn03's Avatar
Default bogging problem
I got a 99 warrior that starts n idles but once u hit the throttle it bogs n dies unless u let the throttle go? Then as it was cranking over n trying to start there's a pinging noise but it only does it when trying to start it? Some advice would be great on where to begin
Old Sep 5, 2014 | 07:17 AM
Raptor450's Avatar
I would start with the parking brake sensor at the clutch perch.
Old Sep 5, 2014 | 07:26 PM
breonn03's Avatar
Default bogging warrior
Can I just eliminate the parking brake
Old Sep 5, 2014 | 08:43 PM
Raptor450's Avatar
Yes, they are junk anyway. Just permenantly connect the 2 wires at the clutch perch sensor, and get a parking brake block-off plate for about $14. They're all about the same but I lke Lonestar stuff lsracing.com
Old Sep 6, 2014 | 10:22 PM
breonn03's Avatar
Default bogging n dies
I looked at it today on the clutch perch assembly there was only the wire going to the bottom n I accidentally broke the plastic housing. I got it to start and idle but still bogs n ddis when I touch the throttle. Also as I'm hitting the electric start it turns over but pings n class n almost sounds like a grinding screeching sound.. would this be a starter clutch wheel issue??? By the way thank you for the help
scram5050
Aug 30, 2024 01:39 PM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
