Polaris predator 90 2005
Old Sep 6, 2014 | 04:52 AM
crossplane's Avatar
Default Polaris predator 90 2005
Hope someone can help,
I have just bought the above quad and the issues are,
1. from tickover (its ticks over nice) its hard to get it in gear, then when it is in gear it seems as if the clutch is draging/constantly engaged and it will not rev up. forward or reverse. It revs fine in neutral
2. the carb floods/drips petrol if the fuel tap is left on.
thanks in advance, I have searched the forums and it seems there are some proper brain boxes on here
Old Sep 6, 2014 | 05:43 AM
Possible front or rear clutch problem causing the problem.Take the cover off,inspect the belt and blow out belt dust.Make sure the idle isn't too high. If doesn't help cleaning clutches/replacing belt on shifting,clutches need to taken apart.Roller wear was a common problem on front clutches. Dripping from the carb is usually a sign of varnished up/worn needle and seat. Service manual can help you find the problem.Pdf manual for 5 bucks.Polaris ATV Service Manuals PDF Download
Old Sep 7, 2014 | 05:23 AM
crossplane's Avatar
thanks for the response, what are the rollers ?
Old Sep 7, 2014 | 08:34 AM
Located in the front clutch. The manual can show you the break down and repair on both clutches if needed plus other trouble shooting guides. A lot better than tearing into something and not have an idea what may be wrong. Just get the manual.Plus adresss the carb problem on leaking either by trying to clean it or best to install a new carb kit. Again the manual can help on this.http://www.ebay.com/itm/Polaris-90-Predator-Carburetor-Carb-Repair-Rebuild-Kit-2003-2006-NEW-/390919822119?pt=Motors_ATV_Parts_Accessories&hash=item5b04a31b27&vxp=mtr
Old Sep 12, 2014 | 02:35 PM
crossplane's Avatar
Thanks for your help. its appreciated
1966F100
Jul 14, 2015 12:19 PM
Shifts
14
Jul 13, 2015 08:41 AM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
Shifts
Jul 3, 2015 07:59 AM
