Is it ok to haul a trailer with an air cooled Yamaha big bear 350
Old Sep 11, 2014 | 12:23 PM
bernhardschmidt's Avatar
Question Is it ok to haul a trailer with an air cooled Yamaha big bear 350
I have a 1988 Yamaha big bear 350cc it's air cooled. Has trailer hitch and rack and I want to know if it is ok to use it for work such as hauling a trailer or equipment. It is air cooled so do I have to worry about over heating the engine?
Thanks
Old Sep 11, 2014 | 05:03 PM
quadsr4me's Avatar
Depends on the loaded weight of the trailer/equipment. How far/often you plan on tugging with your BB?
Old Sep 16, 2014 | 09:21 AM
TLC's Avatar
TLC
The big bear also has a oil cooler to help cool things down and a low range for towing. Atleast my 89 did.
I worked that one hard without a problem.
Old Sep 16, 2014 | 11:45 AM
Smile Yamaha 350 big bear
Thanks that was a very big hrlp
Old Sep 16, 2014 | 05:52 PM
Scooter86's Avatar
Knows Old ATV Questions!
Of course you can haul a trailer with it. Tolerances are typically a little looser in an air cooled motor to help deal with heat issues. Any motor can overheat, just don't overload it and be reasonable about what work it will be doing.
Old Sep 17, 2014 | 08:32 AM
Default Yamaha big bear
Thanks a lot
Old Sep 18, 2014 | 08:53 PM
sandmanrrr's Avatar
In the rain? In the snow? Dumont dunes? How can you expect anyone to answer that stupid question! Jeeez
Old Sep 19, 2014 | 09:51 AM
quadsr4me's Avatar
Ya man, need more info if you want anything more than just general tips, unless you already think you know what the answer is and you're just looking for something that will justify the use you'll be putting your machine through.
Old Sep 19, 2014 | 01:20 PM
Default Bernhard Schmidt
Thanks a lot
Old Sep 19, 2014 | 01:25 PM
scootergptx's Avatar
Supersock
Hired Gun!
I moved a pop up trailer around with my old 325 trail boss. Now it was a smooth and hard surface too. Loose dirt and I'm sure I'd have just dug a hole. Didn't move it far either. Maybe 50 ft at the most.
I wouldn't call it a stupid question, but some more information would help get you a more accurate answer.
Ean
Dec 19, 2022 08:48 AM
Peter_
Jul 18, 2015 07:06 AM
clsharky
Jul 13, 2015 02:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
