HELP:'03 400ex Carb Leaking Out Bowl Drain Tube
Old Sep 11, 2014 | 11:44 PM
Heshan's Avatar
Default HELP:'03 400ex Carb Leaking Out Bowl Drain Tube
After a brief start, gas is pouring out the drain tube on bottom of carb. There is not a hose connected. where does this hose route to, and what can I do to fix this. Thanks in advance for any and all help. I really appreciate it.
Old Sep 12, 2014 | 08:16 AM
The hose is a drain/over flow tube on the carb bowl. If it's pouring out of the bowl probably a float needle(item#21) sticking or worn. You can remove the carb and clean it,but since you have it apart best to just install a rebuild kit. Item # 36 on the parts break down. Dirt Cheap Honda & Arctic Cat OEM Parts & Accessories – Cycle Parts Outlet
Plus carb kits are available on ebay,etc.http://www.ebay.com/itm/Carb-Carburetor-Repair-Kit-Honda-TRX400EX-1999-2000-2001-2002-2003-2004-/171447431897?pt=Motors_ATV_Parts_Accessories&hash=item27eb1032d9&vxp=mtr
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Unzzy66
Jul 11, 2015 10:01 PM
