2004 Trailboss 330 Carb issues
Old Sep 17, 2014 | 07:32 PM
Frank A Tambone Jr's Avatar
Default 2004 Trailboss 330 Carb issues
Okay I have been messing with this bike now on and off for about 4 months, needed a new wiring harness someone put wrong one on, now i can't get it to start or run is a better example. everything is fine now with wiring , i try crankin(yes its getting gas, yes lines are hooked up correctly) it won't start but if i spray carb cleaner if will fire over once then stop ..suggestions?
Old Sep 18, 2014 | 05:05 AM
Getting fuel from the fuel pump to the carb? Carb clean,new carb kit? If you're getting fuel,the carb is ok,then could possibly be an ecm problem. One of the first ones Polaris used. It controls several different functions and if any of the internal circuit breakers fail,could be the problem you're having. Item #18 on the beak down.Dirt Cheap Yamaha, Honda & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Jmuddin284
Jan 19, 2026 07:16 AM
Sjrpp
May 2, 2023 03:59 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
