Fuel Capacity
The Yamaha Timberwolf 250 is a compact all-terrain vehicle. The total weight of the ATV when dry and clean is 438 lbs. The ATV is 72 inches from the front bumper to the rear bumper and approximately 40 inches wide. From the ground to the top of the seat is 30 inches and 42 1/2 inches from the ground to the handle bars.The Yamaha Timberwolf ATV gas tank can hold up to 2 1/2 gallons of regular gas.
This is for a 1999
http://www.atvreviewnetwork.com/enth...VehicleCode=84 The site does not go older but I think there was no changes from 98.
@ 2.5 gal you may get a range of 50 miles.
MANUFACTURER Yamaha
MODEL YEAR 1999
MODEL Timberwolf 4X4
M.S.R.P. * $4,299.00
DIMENSIONS
LENGTH 72.4"
HEIGHT 43.5"
WIDTH 40.4"
WEIGHT 507 lbs.
GROUND CLEARANCE 6.6"
WHEELBASE 44.1"
SEAT HEIGHT 31.1"
ENGINE
ENGINE 229.6cc, Air Cooled, 4-Stroke, SOHC
DISPLACEMENT 229.6cc
BORE X STROKE 71 X 58mm
COMPRESSION RATIO 8.7:1
CARBURETION 24mm Mikuni
FUEL TANK CAPACITY 2.4 gal.
STARTING Electric and Auxiliary Pull
LUBRICATION Wet Sump
DRIVETRAIN
TRANSMISSION 5-speed, reverse, automatic clutch, 4WD
BRAKES/WHEELS/TIRES
BRAKES Front: Dual Drum
Rear: Drum Sealed
TIRES Front: AT 23 x 8-10
Rear: AT 23 x 10-10
OPERATIONAL
SUSPENSION Front: MacPherson Strut/4.9" of Travel
Rear: Swingarm/4.9" of Travel
LOAD CAPACITY Front Rack: 66 lbs.
Rear Rack: 99 lbs..
TOWING CAPACITY 728 lbs.
MANUFACTURER Yamaha
MODEL YEAR 1999
DIMENSIONS
LENGTH 72.4"
HEIGHT 43.5"
WIDTH 40.4"
WEIGHT 507 lbs.
WHEELBASE 44.1"
SEAT HEIGHT 31.1"
ENGINE
DRIVETRAIN
BRAKES/WHEELS/TIRES
Rear: Drum Sealed
Rear: AT 23 x 10-10
OPERATIONAL
Rear Rack: 99 lbs..
Elkaholic
Sep 6, 2015 02:44 PM
