1988 yamaha big bear 350 only one wheel is spinning
Old Sep 29, 2014 | 10:05 AM
bernhardschmidt's Avatar
Default 1988 yamaha big bear 350 only one wheel is spinning
Only one wheel Is spinning on my quad I can still drive it both rear wheels are supposed to spin but while driving the left wheel suddenly stopped spinning and just rolls please help is it expensive to fix?
Old Sep 29, 2014 | 02:26 PM
Question
Only one wheel Is spinning on my quad I can still drive it both rear wheels are supposed to spin but while driving the left wheel suddenly stopped spinning and just rolls please help it is shaft driven (no chain) is it expensive to fix?
Old Sep 29, 2014 | 03:21 PM
Default Bernhard
Thanks a lot where can I get the hub?
Old Sep 29, 2014 | 04:20 PM
Stretch67's Avatar
eBay perhaps.
Old Sep 30, 2014 | 02:13 AM
Check if the splines on the shaft are OK, there is no point fitting a new hub if the shaft is shot.
Old Sep 30, 2014 | 08:08 AM
TLC's Avatar
TLC
You may get lucky. The hubs are made of a softer alloy then the steel rear axle so the spline on the hub should wear out long before the spline on the axle.
When you take the hub off you will find out soon enough.
Old Oct 3, 2014 | 01:59 PM
Default Bernhard
Thanks a lot
Ean
Dec 19, 2022 08:48 AM
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
clsharky
Jul 13, 2015 02:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
