eiger camber
Old Oct 8, 2014 | 09:00 PM
oldmans88's Avatar
Default eiger camber
New to forum but need help.I just changed flywheel on my 2004 Eiger,magnets came off.Now I noticed that the left front wheel tips in at the bottom or at least it looks that way the right side seems to be straight up and down.Anyway how do I check this and is there adjustments that can be made? I see toe in can be adjusted with the tie rods but that's the only adjustment I can see. I don't see anything bent and I believe the manual says 3 degrees camber, just what is camber please help thanks
Old Oct 8, 2014 | 11:01 PM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Camber::
The camber angle identifies how far the tire slants away from vertical when viewed directly from the front or back of the vehicle. Camber is expressed in degrees, and is said to be negative when the top of the tire tilts inward toward the center of the vehicle and positive when the top leans away from the center of the vehicle.
I found that. Hope that helps.
Old Oct 9, 2014 | 11:47 AM
quadsr4me's Avatar
How much tilt are we talking? Camber should be spec'd to 0.3 so should be basically neutral. More importantly, what does the left front wheel look like when you have a rider on the quad? Does it still look off? IF so, it still might correct itself when you get up to speed. I'd be on the lookout for uneven tire wear on that left front wheel but until then, unless there is an obvious tilt (from the sounds of it, even your eyeballing it, you're in doubt), I wouldn't worry too much.
Old Nov 1, 2014 | 03:57 PM
quadrunners's Avatar
you likely have to adjust your shock up a bit by turning a big nut that requires a special tool to turn
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
panicmanic
Dec 15, 2015 01:58 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
metal249
Jul 28, 2015 09:35 AM
baysport
Jul 23, 2015 11:37 AM
