stiff steering in 00' xplorer
Sounds like one of your front hubs is locking when it shouldnt. there is another recent post with simalar problems here "P.O.S. Reverse Polaris", Take a look at that post and see if it applies to your problem. If you think it is I would start with a hub fluid change (check to see if you have any fluid in them also) and a good cleaning out of the hubs and test again. if the problem is still there you will have to take the bad hub apart and see whats up. There are other "hub" posts you can searh on to get more info also. gj
Sep 30, 2015 01:37 AM
