UNI Filter Maintenance
Old Apr 5, 2001 | 12:52 AM
Rainman's Avatar
This is my first Uni filter(had a K&N on my 250X).
Do you guys saturate the entire filter with the filter oil, or just the inner core or outer cover?
Thanks,
Rainman
Old Apr 5, 2001 | 01:26 AM
ScrambledKiwi's Avatar
Put some on, and then squeeze it in. Keep adding untill it starts to squeeze out. The squeeze it out (don't wring)and leave it out of the bike for a couple of hours to dry and drain.
Old Apr 5, 2001 | 01:34 PM
KevinDevitt's Avatar
I only oil the outercover. Seems to work very well.
KD
Old Apr 5, 2001 | 04:03 PM
TheQuadfather's Avatar
Here's what I do to a dirty filter. I pur about a quart of 100% mineral spirits into a stainless steel parts bowl. Put in the Uni, and swish it around, ring it out a couple times, then change the spirits and do it again. Then, I put some dishwashing soap on the filter, and run it under water while wringing it out. I then set it in fron of a small fan for about an hour. I then drop it into a big ziplock baggie, and spray PJ1 foam filter oil on it. Don't skimp, but don't drown the thing. I zip the baggy closed, and wring it around inside, until it's covered very well. Then, I set it in front of the fan with the fan on low for a bit. Your hands are clean, and the filter is ready to go. I bought three filters, one in the bike, and two ready to go. This comes in handy for those weekend rides in very dusty conditions, where you don't have access to a sink in the middle of nowhere.
Hope this helps.
dannytas
Sep 26, 2017 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
caveeagle
Sep 19, 2015 01:20 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
black798
Sep 9, 2015 07:42 AM
