hpd vs aaen steering dampner
Old Sep 16, 1999 | 01:57 PM
jim's Avatar
jim
I tried the HPD 7 clicker steering dampner & then tried the Aaen steering dampner. I think the HPD is a waste of money & the Aaen is worth every cent. I put both on the heaviest setting & ran both over a set of 6" high vertical rocks pretty fast & the HPD set up almost ripped the bars out of my hands. I did the same thing w/ the Aaen setup & I felt hardly anything & I even did the Aaen test w/ a sprained wrist. While on the quad, the HPD unit does not slow you down at all when trying to twist the bars as hard & as fast as you can but the Aaen you can adjust it up where it definatly slows down the quick movements which is what you want. As a side note, the Aaen has cooling fins & 2 grease fitting & the HPD has none. The Aaen is ~$25 more though.The pistons on both dampners seem to have the same tension on max setting except that the Aaen is leveraged differently & thus more resistance. As far as duribility goes, who knows but for those of you looking into a steering dampner, I thought this might help.
Jim Maloney 98 400 Scrambler
Old Sep 20, 1999 | 07:11 PM
Jack's Avatar
Jim - Thanks for the info. I'm going to check with Aaen about one for the Sp500 and the 400SS. My old one off the 400SS is going on Chris '95 Sport.
<A HREF="http://www.godigital-design.com/schultzmotorsports">Schultz Motorsports</A>
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
