Slow for 4X light to go off
Old Nov 4, 2014 | 05:42 PM
Oldbear's Avatar
Default Slow for 4X light to go off
2005 450 Kodiak with 4X and differential lock. It goes into 4 wheel instantly and the differential lock works fine but when the button is pushed to go back to 2X sometimes it takes forever for the light to go off. I use to could put it in reverse and it would go off pretty much right away. I don't really know if it actually goes back to 2X right away and the light is stuck on or if its still in 4X. While typing this I just thought maybe I could jack all 4 wheels up and see what happens. Anyone else have this problem or any suggestions. Thank you.
Old Jan 21, 2015 | 07:54 AM
Oldbear's Avatar
It does work properly even though the light hardly ever goes off so I'm not going to worry about it.
Old Jan 21, 2015 | 09:40 AM
TLC's Avatar
TLC
I,m on my 2nd 350 Grizzly 4x4 and both had a good delay for the 4wd light to go out once you went back to 2wd.
I also quit worrying about it.
To test the 4wd is on or off I just nose up to a tree or wall and give it some gas, you can tell if the front wheels are in the game or not easy enough.
fordfaithful21
Dec 7, 2015 05:52 PM
Minimod
Sep 10, 2015 09:20 PM
Steeldon
Sep 9, 2015 09:38 AM
black_thunder
Sep 6, 2015 04:41 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
