2000 kodiak 400
Old Nov 22, 2014 | 09:00 AM
25grizzlyrider660's Avatar
Default 2000 kodiak 400
hey there everyone,
I have 2000 Kodiak 400 that the cdi keeps going bad. Does anyone else have this problem, or know what needs to be done to fix this problem. When I bought this bike the computer was bad, and I purchase a new one. Now that one has gone bad as well. This is an expensive problem to keep fixing.
Old Nov 22, 2014 | 11:58 PM
rider77's Avatar
Any known history of the machine being flooded out? Is it getting wet somehow? Are you using factory replacements?
Old Nov 23, 2014 | 03:52 AM
When you get a new CDI there is a warning that the earth to it must be connected or it will blow, so an intermittent earth fault could be the problem. I once blew a new CDI when I fitted it to a bike that was overcharging. With the engine running, check the voltage across the battery doesn't go over 14.5v. If it does, fit a new regulator.
Old Nov 23, 2014 | 10:21 AM
TLC's Avatar
TLC
Defiantly something wrong since Yamaha has no known issues with CDI.
My old 1989 Big bear is still running with the same CDI box after 26 years.
Old Nov 23, 2014 | 05:34 PM
Hey there,thanks for your speedy reply.there is no known flood or submerged damage to this bike.when I bought the bike it wasn't running,so I bought a factory cdi from partzilla.300$
I haven't checked voltage because it want stay running long enough,but a bad ground would make since. Should I run an extra ground wire straight off the computer.
Old Nov 26, 2014 | 07:49 PM
DGNAZ's Avatar
Check all of the grounds. Engine, frame, etc. Anytime you replace a computer this should be done.
Old Jan 17, 2015 | 10:08 AM
Lil bear's Avatar
It could be bad wiring under the gas tank and the heat from exhaust pipe or coil
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
