400 Scrambler with loose steeering
Old Sep 17, 1999 | 12:24 AM
Sburdman's Avatar
I remember reading a post back a month or so ago about play in the front end on a Scrambler. Didn't pay much attention then but now that I have one and after several rides the front end has some play. I can turn it a little left and right without the wheels moving. It is more of an annoyance than anything. Anybody remember what the solution was. I know my TB with many more miles on it doesn't do this.
Scott.
Old Sep 17, 1999 | 01:45 AM
keithb's Avatar
I am in the process of tightening up the steering on my 1991 Trail Boss 250. I also have a Sport 400 and the steering is similiar to your atv. There are 2 bushings that seem to wear over time. One is about 1/3 down the steering shaft, I just reaplced mine last night. This cleaned up any "Front to Back" slack. There is another bushing I have on order from the loacal dealer. It sits right at the bottom of the steering arm below where the tie rods connect. This is quite worn on my atv. This affects the side to side play. It is riveted in place. You may also want to check the inner and outer tie rod ball joints for any looseness.
Hope this helps. Loose sloppy steering is a pain in the butt.
Keith
Old Sep 17, 1999 | 08:10 AM
A400L's Avatar
HPD makes bronze a replacement for the lower post bushing ($40). Also check your tie-rod connections as well.
Jerry Goodman '99 400L, '98 TBlazer
Old Sep 17, 1999 | 07:53 PM
Sburdman's Avatar
Thanks for the help.
Scott.
Old Sep 20, 1999 | 12:24 PM
Chris Picciotto's Avatar
The HPD lower steering bushing is awesome. It takes a little patients and skill to install but front end play is a thing of the pasts. I ride in the mountains with tons of rocks My steering was so trashed i had to replace both outer tierod ends, my lower left ball joint, the steering post and the lower steering bearing. I used the new Hot Seat steering post which is stronger and lighter ( not nessisary ).
The HPD steering bearing makes the steering solid and i have had no additional problems. I have even added an Aaen adjustable steering dampener to smooth out the ride. I asked Darrel Olson ( HPD ) if they are going to make one for the top bearing but he said he hasn't gotten too many calls for that.
Chris Picciotto
99 Scrambler 500
Old Sep 20, 1999 | 07:42 PM
quad_man's Avatar
I noticed the new Scrambler don't have the zerk for the top bearing on the steering post. Anybody know why they did this, or what the gain was? If I need to replace mine, I would prefer the bearing to be sealed to save grease, since that part of the quad isn't under water, much. :-)
Adam
Old Sep 21, 1999 | 12:01 PM
rennym's Avatar
I noticed that the rivets on the lower bushing were worn on my machine. I drilled them out and put bolts in place and it tightened it up. I will still have to replace it in the future, but for now it will do.
RM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
