Having a little scare with the polaris
Old Nov 24, 2014 | 07:11 PM
Polaris11's Avatar
Exclamation Having a little scare with the polaris
I recently bought a 2006 polaris sportsman 500 H.O EFI. Today when I tried to turn it on I heard a super load Pop kinda like a gun shot, curious is to what that is? It was being used heavily before it happend, trying to pull my moms car out of mud, it felt pretty hot (the engine). Anyway I'm a little curious for the noise and what i have to fix.
Old Nov 24, 2014 | 07:30 PM
Polquad498's Avatar
So what happened next? Shut it down, road it just fine, won't move...
Old Nov 24, 2014 | 07:39 PM
Polaris11's Avatar
After I turned it off, started it back up and nothing seemed a problem
Old Nov 25, 2014 | 07:06 AM
scootergptx's Avatar
Supersock
Hired Gun!
Sounds like a backfire maybe?
Old Nov 25, 2014 | 07:48 AM
Polaris11's Avatar
Exclamation Would i need to fix anything in that case?
Would i need to repair any parts?
Old Nov 25, 2014 | 08:05 AM
Supersock
Hired Gun!
If it was just a one time thing, I wouldn't worry too much about it. If it keeps doing it, then I'd start to check things out.
Old Nov 25, 2014 | 11:02 AM
Efi hickup which is common considering all the electronics involved.Had a few do the same thing. But could be starting of a sensor wiring problem that many of them had. Just ride it and see if it starts happening again. If it does,then most times it's in the t-bap harness and wiring. One of the symptoms that it can show. Back firing,erratic idle,hard starting,etc.
Old Nov 25, 2014 | 09:29 PM
Polaris11's Avatar
In that case what would I need to fix? Today it happend again, also when i started it up it just died on me but started back up. It's annoying but not a huge issue just want to make sure I don't need to fix anything
Old Nov 25, 2014 | 11:37 PM
pete37922's Avatar
take the garbage spark plugs out & install NGK plugs !!!
Old Nov 26, 2014 | 07:57 AM
Then check the t-bap harness wiring for any bare or soft feeling wires that could have shorted out internally.Plus you can check the tps harness wiring also. Sometimes jiggling the wiring may reveal the offending wiring harness while it's running. Best place to get a new connector and wiring if needed is here.Only The Best
