lt230s new top end
Old Nov 27, 2014 | 07:33 PM
Burnpile230s's Avatar
Default lt230s new top end
I just rebuilt my 86 lt230s. Wiseco 10:1, bored and honed, valve job, the works. Fired right up. But there is a loud hammering noise. I took the head off and checked the valves, piston, rockers, cam, all of it looked fine. Valve lash is good. Exhaust gasket it tight. What am I missing? When I touch a long extension to my engine and my ear, I can't find the knock. I put 93 octane in it, it it possible that it is pre-igniting and not something mechanical?
Old Nov 29, 2014 | 01:24 AM
As it turns out I had set my valve lash at exhaust TDC instead of intake TDC, giving me about .125 instead of .002-.003. Duh right? But she runs hard, now I need a 14/39 or 37 tooth sprocket set cause first and second are worthless lol.
Old Jan 6, 2015 | 05:54 PM
jel08270's Avatar
Sorry to say this but I did the same thing I bored My 87 LT230s out .100 Wiseco Piston and my knocking noise was the Connecting Rod bearing.It just had a little to much play in the rod.I got a new Rod kit n its super quit now.Machine Shop charged Me $80.00 to press on new Rod n Bearing.LT230 Rod kits r about 100.00 bucks on Ebay n you will need complete gasket kit.
Hope you find out its something else then the rod but it sounds exactly like what I went thru.
Let us know what you find out.
Old Jan 10, 2015 | 10:29 AM
It turned out that my valve lash was set on TDC exhaust instead of TDC intake. The noise was the valves clacking. My rod was tight, a few thousands side to side, but none up and down, that is within tolerence.
Old Jan 10, 2015 | 06:50 PM
jel08270's Avatar
Default Good news
Well that's good news,changing the rod is a big job.
lonerider856
Oct 13, 2023 03:45 PM
Shooterj2003
Jun 21, 2015 07:51 PM
scaldwellk
Jun 19, 2015 05:08 PM
230Srider
Jul 17, 2003 06:30 PM
QuadDude05
Jan 3, 2001 01:35 AM
