ADC Leak Help
Old Dec 16, 2014 | 09:33 AM
ZAKAZIM's Avatar
Default ADC Leak Help
Hello all!! I have 2008 Polaris 700 X2 and looking today it seems as it has developed a leak at the front prop shaft seal going it the ADC front end. Question is, is this a pain in the A$$ to change along with knowing how expensive It is to repair/ replace it this something i need to leave with a pro and take it into the shop.
Thanks in advance.....
Old Dec 16, 2014 | 01:22 PM
They don't make it easy on you. Not so much on being able to do it,but what you have to buy. "Cover assy" comes with new cover, seal,0-ring and bearing.Unless the bearing is worn also,guess the kit might be worth it,BUT bearings can always be matched up at a parts house along with o-ring and seal I suppose and I'm sure some have done it. At the shop we just ordered the kit as most dealers do. Cover alone is $81,the "assy" is $99,so bearing,seal,and o-ring by their calculations are only $18 bucks,if you could only buy them separately..
Item#7 versus #21.Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
To repair this you have to remove the spring pin from the prop shaft at the front diff.Knock the rear u-joint/yoke back on the transmission shaft far enough for the front prop shaft yoke to fall off the diff shaft.Easy if you have an air hammer with a flat,dull bit. Move the prop shaft over to the left to be able to remove the cover screws.Always replace the spring pin!
Old Dec 16, 2014 | 06:16 PM
ZAKAZIM's Avatar
Thank you OPT !!
I have found a post from another site with the grease seal after market number and was just going to replace this seal but now i,m thinking i need to go deeper and replace the baring and such...... im good with this but $100.00 for the Polaris kit is bunk. I am a hands on man and will just do it with after market parts.
Old Dec 16, 2014 | 08:00 PM
Originally Posted by ZAKAZIM
I have found a post from another site with the grease seal after market number and was just going to replace this seal but now i,m thinking i need to go deeper and replace the baring and such.. I am a hands on man and will just do it with after market parts.
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
