warrior 350 wont start
Old Dec 17, 2014 | 01:37 AM
Nixonsbudz's Avatar
Default warrior 350 wont start
Bought a 95 yahama warrior 350 running but needed a carb rebuild. I did that and started it right up and let it run for 20 min then it died and would not start back up. Replaced the stator, pick up coil, ignition coil. Has a blue spark and is getting fuel and won't push start. It just cranks over and over but still nothing. Any help would be very appreciated.
thanks
Old Dec 17, 2014 | 03:42 AM
Clean the carb out again. If it needed the first clean, dirt or water had got through from the tank so, after running a while, some more may have got through and blocked the carb.
Old Dec 17, 2014 | 04:38 AM
Nixonsbudz's Avatar
That's what I 1st thought but tried spraying carb cleaner into the carb and nothing. Then tried dumping a cap full of gas into the spark plug and still nothing. Usually one of those 2 things would get it to turn over for at least a couple seconds
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
