Changing plow blade direction without getting up.
Old Jan 12, 2015 | 03:13 AM
CarlR's Avatar
Default Changing plow blade direction without getting up.
Hey folks.
2003 Sportsman 500, with OEM plow blade.
The blade has three positions, left, center, right. As far as I can tell, you have to get off the machine, depress a locking lever, and move the blade by hand.
Has someone come up with a way to do this without getting off the machine?
I might try to figure out a way, using two levers and a few brackets, but I'd rather see if someones already done the R&D first
Old Jan 12, 2015 | 11:53 AM
Can't remember what forum it was on but a guy put an eye bolt through the top of the blade on each side. He then put a pulley somehow on the front of the quad going down to the lever that allows you to pivot the blade. His lever had a hole in it so he put threaded link through it and attached a rope. He said he made one piece to pull up the lever and one piece of rope to go from the left eye bolt on top of the blade, around his back and to the right eye bolt. So he pulls the lever rope first, and then whichever side he wants to pull the blade towards. Haven't tried it myself but it seems like it would work.
Old Jan 15, 2015 | 09:33 AM
Hotdogmb's Avatar
You could rig up something like an old throttle cable to pull the locking lever up and then just push the end of the blade into the snow bank or something and have it pivot the direction you want and then release the lever.
Old Jan 17, 2015 | 02:36 AM
mtpockets's Avatar
Oddly enough what worked for me was to put side deflectors on my blade. After that I basically kept the blade in the straight position and for my type of plowing, a large square driveway, I never needed to angle the blade from that point!
Old May 18, 2021 | 08:21 PM
crandreww's Avatar
Default I think this might be the one you are talking about https://youtu.be/IaPoLdykhJE
Can't reer what forum it was on but a guy put an eye bolt through the top of the blade on each side. He then put a pulley somehow on the front of the quad going down to the lever that allows you to pivot the blade. His lever had a hole in it so he put threaded link through it and attached a rope. He said he made one piece to pull up the lever and one piece of rope to go from the left eye bolt on top of the blade, around his back and to the right eye bolt. So he pulls the lever rope first, and then whichever side he wants to pull the blade towards. Haven't tried it myself but it seems like it would work.
Old May 20, 2021 | 10:33 AM
Kymco 450i's Avatar
With some planning and experimenting I found I could just leave my blade on angle and never have to change it. The east side of my drive is lower than the west side so it benefits me to push all my snow to the east side. I start at one end and go back and forth longways on my 300 ft drive and just keep pushing the snow to one side. Never need to change the blade angle. Think about your plowing pattern, you might be able to do the same....
ghost civic
Jan 15, 2020 07:43 AM
neo27ny
Aug 24, 2015 02:02 AM
readymixer169
Aug 21, 2015 10:05 AM
Gtsordo
Jul 22, 2015 01:27 PM
Gtsordo
Jul 13, 2015 10:38 PM
