outlaw carb question
Old Feb 1, 2015 | 02:29 PM
ultrakillpv's Avatar
Default outlaw carb question
for the fcr carburators they have the throttle position sensor on it does anyne know what will happen if i run it with the sensor not plugged in? can it be ran effectvely without it? what are the effects of running it with out the sensor cnnected?
Old Feb 1, 2015 | 02:35 PM
Several differnt posts/forums on this that can help you decide what you want to try..TPS on Keihin FCR - necessary or not ? - Intake - Jetting / Fuel Injection - ThumperTalk
https://www.crfsonly.com/forum/viewt...be1a222ce8bc31
Old Feb 1, 2015 | 03:19 PM
thanks that all helps so the tps connects to the cdi and i ask this is because on mine i have a cv carb and i want to switch to a fcr and so far that i have found ill need to upgrade my cdi to run the fcr carb on my cdi it only has a single port and wont have the extra for the carb so is this correct?
Old Feb 1, 2015 | 03:24 PM
I guess as I've never swapped carbs on the Outlaw at the shop. Had enough problems just keeping the Outlaw and the Predator repaired and running from all the crazy people that bought em..
Old Feb 2, 2015 | 02:01 PM
quick question on jetting my carb my evelation is around 2,600 above sea so what size jetting should i use i have a silp on and filter w/out lid?
would jetting be the same for both cv and fcr carbs
Old Feb 2, 2015 | 02:34 PM
Two different types of carbs. Jetting will be different along with other things. If you're getting a new carb designed for this use it should have some sort of jetting guide.Plus this might be able to help you.carbkie.html, Keihin FCR Carb Tuning Procedures
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
