Kodiak Oil Drain Plug Not Tight Enough?
Old Feb 2, 2015 | 03:44 PM
Allistah's Avatar
Default Kodiak Oil Drain Plug Not Tight Enough?
Hey all --
We got a 2005 Kodiak 450 4x4 a couple weeks ago and this past weekend I changed all of the fluids: oil, coolant, and front/rear diff. I noticed that there was a drop of oil hanging off the oil drain nut. I tightened it to the proper spec as per the service manual - can't remember how many pounds it was off hand. I wiped the drop off and it doesn't seem to be happening again but I'm sort of paranoid about it now.
Is it possible that it just needs to be a little bit more snug so I won't have to worry about it going forward?
Thanks,
-Alli
Old Feb 2, 2015 | 05:15 PM
New drain plug washer may solve the problem.Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Feb 3, 2015 | 04:50 AM
Just check it again after standing for a day or two. If it hasn't leaked again it will be OK. When you drain oil it runs down the sump a bit and when you put the plug back this oil can collect on the plug which is now the lowest point.
Old Feb 3, 2015 | 10:22 AM
Allistah's Avatar
Yeah it doesn't seem to be leaking any more. I guess that oil was from around the rim of the bolt head and also like you said. I thought that I'd wiped it pretty clean when I reinstalled it so it surprised me when I saw it. Thanks for the post - it was helpful in knowing that it's sort of expected and that its ok now.
RedRancher
Oct 15, 2020 01:45 PM
SDR-II
Sep 29, 2015 01:06 AM
Jul 28, 2015 12:12 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
RedRancher
Jul 10, 2015 06:36 PM
