CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
Can-am snow plow issue
Old Feb 8, 2015 | 04:40 PM
bigdog_mike's Avatar
Default Can-am snow plow issue
Had an issue with my Can-Am snow plow frame, was pushing the large snow fall in the Detroit area and a large boulder of snow that was pushed into my driveway by the road plows and when I tried to move it, the plow frame got bent. My question is does any one have the Can-Am plow on their ATV, as I need to get the plow frame angle between the first bend forward of the mounting point. As I plan to straighten the plow frame and reinforcing the bend area. Buying a new frame is very costly so repairing the bent frame is the only option. Thanks for any help in the matter...the angle can be measured either from the bottom side by using a straight edge and measure the angle between the first bend and the mounting point which should be the smaller angle that is less than 45 degrees, guessing here, or measure from the top side of the plow frame between the first bend and the straight frame forward of the mounting point, this angle should be larger than 90 degrees...see attached pic of the plow frame bendName:  CAN-AM-PLOW-FRAME-02_zps61a545a6.jpg
Old Feb 8, 2015 | 05:54 PM
NLWarrior01's Avatar
I have the same frame but unfortunately won't be near it until thursday. If I can think to do so I will check the measurement for you. Good luck in the mean time.
Old Feb 9, 2015 | 11:45 AM
How long have you had the plow, Bigdog? Is it still covered under any kind of warranty?
baysport
Jul 23, 2015 11:37 AM
Gtsordo
Jul 22, 2015 01:27 PM
RedRancher
Jul 10, 2015 06:36 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
cornermike
Jul 8, 2015 11:44 PM
