2-1999 sp500's. Original coolant,maybe time to change!
Old Feb 28, 2015 | 06:59 AM
Fender bender's Avatar
Default 2-1999 sp500's. Original coolant,maybe time to change!
Opt,
Have 2 1999 sp500's that have never had the antifreeze changed. Do you think this has done any damage? And wondering whats the easiest most effective way to change them both out and also wondering if can use any standard green antifreeze such as that from Walmart etc.- Or must it be POlaris antifreeze?
Appreciate the help!
-Jon
Old Feb 28, 2015 | 09:43 AM
Not if it hasn't over heated and the fan works ok.Just drain the radiator,install a garden hose in the radiator and run the engine until clear water drains out. Let it drain completely,close the drain,lift the machine up with tires off the ground and add coolant.Run without the cap and let the fan cycle on and off a few times to help remove trapped air,add coolant as the level drops. You can also squeeze the hoses as the manual states to help on this. Top off coolant in the radiator and coolant bottle.You can use almost all type coolants as most are ok for aluminum radiators now. 50/50 or 60/40 as Polaris uses. Your choice on this.
Old Feb 28, 2015 | 09:14 PM
I gather the radiator has a petcock? Or should I pull a hose off instead? Also, just jack the front wheels off the ground when refilling? Appreciate it opt.
Old Mar 1, 2015 | 03:46 AM
Drain valve #14.Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse Yes have the front wheels off the ground a little helps to remove air pockets from the system faster.
WilliamBos
Sep 30, 2015 08:08 AM
wbfjim
Jun 8, 2015 06:20 PM
UPLou
Jun 7, 2015 09:42 AM
neilbedwell
May 31, 2015 11:11 AM
blaze_master
May 26, 2015 11:18 AM
