98 400l xplorer gas line freeze
Old Mar 2, 2015 | 02:18 PM
jepik's Avatar
Default 98 400l xplorer gas line freeze
98 400l xplorer..runs good in weather above freezing..20 degrees or less gas line freezes up..already had put isop. in before using..ran fine for about 30 min. shut it off..then would not start.. put in heated garage for a hour and it fired up..starts up idles fine and in about 10 min. it will idle about twice as fast as normal when its out in freezing weather..
Old Mar 2, 2015 | 02:43 PM
Don't like Heet or any product like it,but some do. Sounds like it's running lean also.If you're running the stock 200 main,30 pilot,you might think about bumping them up until warmer weather. Plus cold weather's hard on seals and gaskets just as much as hot weather. Could be sucking a little cold air. You can spray contact or carb cleaner around the intake and gaskets when it's idling high and see if the rpm changes. If it doesn't then could just be needing jetting change or possible crank seal leaking.Seal behind the drive clutch is usually the main culprit on seals.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Alex G.
Sep 11, 2017 11:38 PM
Mar 21, 2016 06:30 PM
rockinkgin
Sep 25, 2015 01:52 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
