"T" mark
Old Mar 23, 2015 | 05:06 AM
ac10's Avatar
Default "T" mark
Picked up a 85 250 sx...no "T" mark on flywheel..only small mark for TDC.Anyone know the Degrees before top dead center the valves close so I can set the valve timing.Any other way to figure out the "T" mark?Thanks.......
Old Apr 23, 2015 | 10:48 AM
craigslistbuyer67's Avatar
The way I do it is to pull the plug out and pull it til the piston is at top dead, then spin it back a ways and feel the valves to know where you need to stop it at.
Old Apr 27, 2015 | 10:46 PM
ac10's Avatar
Default tdc
yes the mark on flywheel wasTDC. That's where I set the cam sprocket to and bent the exhaust valve..A knowledgeable guy told me that cam chain was shot...he was right.Had a bad rattling noise that sounded like piston slap but when I replaced chain motor was quiet..
caveeagle
Jun 13, 2023 07:05 PM
BYC
Sep 25, 2015 02:10 PM
black_thunder
Sep 20, 2015 10:21 PM
Canamaniac!
Sep 15, 2015 06:19 PM
