sooo...i bought the 97 scrambler 500 HO..have some questions
k the quad runs fine for a short ride then boggs down, i noticed 2 fuel filters and maybe a "kinda" kinked line(not sure if its a fuel or vacuum line yet, its the middle line in the pic if it loads) so im thinking replacing fuel lines ans put ONE fuel filter in...
second..the guy said the awd works but i put the rear in the air with only the front tires on the ground, hit the awd button and put it in gear, give it gas and the front shafts are spinning but the front wheels will not engage at any rpm, what could it be?
and last...what do i need to disconnect the overide for reverse and not disable the awd(i thought i read it messes with the awd when disconnecting the reverse overide on awd machines)
Just check that you have power to the gray wires at the awd connectors under the panel while in awd mode.If not could be the gear position switch at the shifter.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Just pull the black wire from the limiter module. Defeats the limiter to where you have full power in reverse,But you may still have to push the over ride for awd.Plus who knows what po did on the fuel lines. May need to install a carb kit. On something like this I'd start at the front and work all the way to the back. Plus do a full service on the machine. Don't trust what po may have said has been done.
ohhh yeah, another thing...my light cluster, the high beam indicator works but the neutral and reverse lights do not, and im worried the temp might not work if needed...is there a fuse or fuses on this machine i can check...i figured they should all work if the high beam works...or do u think it could be related to the gear position switch, maybe its bad or not connected? my first awd quad so please bare with me lol
Check that you have power to the combination indicator/bulb. I you do,could be blown and need replaced. http://www.cyclepartswarehouse.com/f...1997&fveh=5437 Plus get this!! http://visit.tradebit.com/visit.php/...75/264163234/9
so theres 1 bulb for neutral and reverse? and a separate bulb for the high beam indicator? and is that the right manual, says 85-95...mines a 97..and is that a no on it being gear selector switch related?
its kinda freezing outside so im not running out messing with it at the moment..trying toget info before i tear into it
1 bulb for hi beam,combo bulb for n/r. Can't rule out the switch if the awd indicator doesn't light up.Changed to the correct manual.. You have to recheck my posts at times as I do edit from time to time.
