part id
Old Apr 4, 2015 | 05:47 PM
princejj's Avatar
Default part id
Got a Chinese quad for my son today and can't figure much out as far as brand there is no stamps anywhere. The problem I'm facing now is I'm missing a part on it and not sure what I'm missing. Directly under the seat on the same bracket as the battery box there is a 4 pin female connector that is missing whatever it's supposed to plug in? Any ideas? I can try to get a pic loaded if I can figure out how to do so but figured I'd try by describing to start
Old Apr 4, 2015 | 07:01 PM
princejj's Avatar
After looking at pics online I think it's a kazuma panda
Old Apr 5, 2015 | 02:13 AM
MPDano's Avatar
Does it run?
Old Apr 5, 2015 | 07:42 AM
princejj's Avatar
currently it will not even turn oveR. I hooked power to starter directly when i went to look at it and it turns over but to just press start button nothing happens
Old Apr 6, 2015 | 09:20 AM
supermanotorious's Avatar
Winchmaster 5000
sounds like a wiring issue, are there any fuses you can check?
Old Apr 6, 2015 | 09:35 AM
princejj's Avatar
Im guessing whatever is missing thats supposed to plug into the 4pin connection is the problem. Bought it with it missing guy didnt know what went there and im having hard time figuring out what it is. I was hoping someone had one and could tell me what goes there. Right off positive cable from battery is the fuse then couple inches further is a split in the wiring where 5 wires go into a 4 pin female connection. Looks like it should be right under seat maybe connected to back side of battery box theres a clip there with nothing attached
Old Apr 7, 2015 | 05:14 PM
princejj's Avatar
I dont know how to add pics to this post but i took some and mad an album on my profile. If anyone could help me out on id of quad and what plugs into the connector in pic that would be very appreciated. Or explain how to load a pic to a post there is two buttons above the massage box but they want a url of a pic and there on my phone. I have a little boy itching to ride this thing. Thanks!
Old Apr 7, 2015 | 08:00 PM
atv-wheeler's Avatar
The 4 pin connector could be a missing relay or the cdi it self.
Old Apr 7, 2015 | 09:54 PM
princejj's Avatar
I initially thought cdi but i cant find 4pin cdi anywhere. They are all 5 pin or 4 + 2 pin or 6 pin
Old Apr 7, 2015 | 10:15 PM
MPDano's Avatar
Voltage regulator according to this manual on the Panda wiring diagram. Plus it's a 4 pin. Look at page 26 on this pdf.
http://www.goscoot.com/kmx110_manual.pdf
http://www.ebay.com/itm/Voltage-Regulator-GY6-ATV-Honda-Kazuma-50cc-90-cc-110-CC-Scooter-12-Volt-/390659466908?hash=item5af51e669c&vxp=mtr
