Another Jetting question
Old Apr 8, 2001 | 02:48 PM
sparkster's Avatar
I have a 96 scrambler with a DG pipe and silencer. I usually ride at ruffly 2480 ft above sea level. What jet size should I be running.
The temp. will range from 40 to the 90's in degrees but mostly around 60-80 now that summer is coming.
Also, what size should I use if I went to around 4000-4800 ft at the same temperature.
thanks for any help
Old Apr 8, 2001 | 09:48 PM
sparkster's Avatar
I'm sure someone out there can help me. I'm going riding this weekend and need my machine to be running at it's best. I ride with a few honda's and I can't let them beat me. Please and thankyou!!!
Old Apr 8, 2001 | 10:58 PM
Crawdad's Avatar
You need to read your plug really to see if you're running too lean or too fat. Lowest would be 230 but you should be able to go with a 250 with an aftermarket pipe. I ran a 270 for awhile last year but it was in the fall so it was a little cooler. If you go up to the higher altitude drop your normal main down by 20.
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
